700 hp? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2013, 08:17 AM
700 hp?
I have a 1985 chevy c10 and I'm wanting to know if I could get 700 hp and 400-600ft/lbs with a 350 bored .040 over and 4 bolt main? I was think something like supercharger/ nitrous. Thanks
Old 04-04-2013, 08:29 AM
vinniekq2's Avatar
yes,with a power adder 700 hp can be done easily
Old 04-04-2013, 08:30 AM
Tall order. Doable but not cheap. I've seen such small blocks. The Nova ProCharger used as a demo car for Super Chevy shows in '09 did it. You can build a 400 HP version fairly easily, and add a 300-fogger...
The supercharged engine will "last" longer than the nitrous engine, but still, not much. You might consider stroking it to get a little "closer" with the base build, then add the goodies. If it's for the street and you want any semblance of practicality, use a big block...
Jim
Old 04-04-2013, 08:40 AM
I forgot to mention it is a street strip use, and the spending unit is $6000-$7000
Old 04-04-2013, 08:44 AM
vinniekq2's Avatar
budget
thats about 1/2 of what you need,not counting the drive line parts to handle the power and suspension to plant the power
Old 04-04-2013, 08:47 AM
I also have a rebuilt th350 with b&m shift kit and I ve changed the gear ratio in the rear end to 3.73
Old 04-04-2013, 09:03 AM
vinniekq2's Avatar
whats the purpose of the vehicle? why 700 hp?
A rebuilt t-350 will last a couple months behind 700 hp.The stock rear end might last a little longer as long as you dont use big slicks. better axles are in order and a t-400 is a lot stronger.
You will need proper traction devices including shocks.Spring rates may need to be changed?
700 hp in a heavy truck is a poor way to go fast
Old 04-04-2013, 09:08 AM
[QUOTE=vinniekq2;1663089]A rebuilt t-350 will last a couple months behind 700 hp.The stock rear end might last a little longer as long as you dont use big slicks. better axles are in order and a t-400 is a lot stronger.
Okay well what would I need for the 350 to have the 700hp
Old 04-04-2013, 09:13 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
My question is why a goal of 700hp??.
vinniekq2's Avatar
what power adder will you use? are you going to upgrade drive line first?
Old 04-04-2013, 09:15 AM
vinniekq2's Avatar
1gary is the best guy here for big horse engines
I asked that same question
Old 04-04-2013, 09:17 AM
I mainly just want to see how much hp and torque I can get out of $6000-$7000
Old 04-04-2013, 09:19 AM
vinniekq2's Avatar
why?
hp is not as expensive as reliability.
How long does it need to last? a few days? a month?a year?
Old 04-04-2013, 09:20 AM
Supercharger and when I'm putting the engine and transmission in ill put in a new drive shaft
Old 04-04-2013, 09:32 AM
vinniekq2's Avatar
get your transmission/converter/cooler installed.Make sure the diffs center section is ready,install the axles.
Then if I were you,I would PM 1gary and get his formula for a 700 plus HP engine.
Do you plan to use a roots type blower? what size? High boost pressure or low?Is the 8k just for the engine or is that to also buy blower and carbs? custom headers and exhaust will cost $2500
700 r4 gman398 Transmission - Rearend 1 10-13-2009 10:43 PM
Th 700 Id paulo1 Transmission - Rearend 5 06-08-2008 08:23 PM
another 700 03eiger Transmission - Rearend 1 02-08-2008 03:17 PM
700 R4 osw Transmission - Rearend 0 06-18-2006 05:47 PM
700-r mayday3045 Transmission - Rearend 5 04-20-2006 09:03 PM
