700 R 4 Shifting Too Soon - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2003, 03:13 PM
New Member
I have a TPI 350 (L 98) and a TH 700 R 4 out of an '86 Corvette in my El Camino. My son grenaded the original 'Vette 700 R 4 so we put in a 700 R 4 out of a ? from a bone yard. We also swapped the original differential. Now the tranny shifts too soon. What needs to be done to make the tranny shift later. It now shifts at about 22 MPH out of first. I think it should shift at about 38 MPH or so.
Benji
Old 07-09-2003, 05:26 PM
your TV cable will need to be readjusted assuming you have the correct cable(the one from the vette tranny should work fine)
Old 07-09-2003, 10:13 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
38 mph is wound really tight for 1st?
Mine shifts at 18 mph into second, into third at40-42 well scratch each time.(Elcamino with 373s)
Also have a 3/4 ton BB suburban with a 700 shifts about the same.
Troy
Old 07-10-2003, 03:41 PM
ginostef's Avatar
New Member
&00R4 Shift too soon
700R4s shift based on the TV cable position. Swapping can often lead to a misadjustment. Here's the catch - you cannot adjust this by feel, or wind in/out a few turns, as it is totally an issue of the pressure being developed internally. You need to get yourself a pressure gauge, screw it into the service port of the tranny, (with a 6ft hose), and adjust the TV so that the pressure just starts to rise when the throttle is pressed. There is a setup procedure you need to follow exactly or you can expect to replace the transmission in the next few hundred miles - it will go bad! Just like slipping the clutch big time - this is wearing the hell out of your tranny. Go check out www.700r4.com and copy their instructions for setting up the TV - they give you everything you need, as well as ability to buy their pressure gauge assembly to do just this same thing. Good luck! (PS - I had this problem when I got an unknown 700R4, rebuilt it, and skipoped it into a 40 Chevy coupe behind a ZZ4. Really hosed up until I followed the insructions at Bowtie Overdrive - assuming all else is okay with the tranny, this will do it!)
Old 07-10-2003, 07:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Since there is a mention of the rear diff swap out ,,,,, perhaps the current diff has a bit lower gear ratio ??
This would cause the tranny to shift sooner , along with the mentioned mal-adjusted TV cable.
There is also the possiblity that the replacement tranny is calibrated differently from the unit that broke.
Old 07-11-2003, 09:17 PM
mr.chevelle's Avatar
It is important to use a pressure gauge when sitting the TV cable.I learned this lesson the hard way.I got the gauge at are local napa store for it seems like about 60 bucks.Its real easy to do,i followed the instrutions out of CHEVY magazine and have had no trouble since.I know many companys sell any thing you will need to set it up properly.Good luck
Old 07-13-2003, 03:51 PM
New Member
Run, do not walk to NAPA or your favorite parts store and get a Automatic Transmision and Oil Pressure Gauge from K-D Tools. Cost ya $50-$60 and is far better for setting up the 700R4.
I followed the directions on Certified Transmissions http://www.certifiedtransmissions.co...ves/INS008.htm
They also give the expected prssures for each gear.
I just finished and NOW I'm happy with my new 350 and 700R4!
