Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700-r
Thread: 700-r
Old 04-20-2006, 08:03 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by mayday3045
i have one ut of a 83 suburban of my dads. never did alot of four wheeling in it. just wondering if it could be done or if its cheaper to buy a used 2wd 700.
As I mentioned , about half of the guts of the tranny need to be removed. Then you remove a snap ring and the output shaft slides out the rear of the tranny.
You slide in a 2WD shaft, reinstall the snap ring and remainder of parts.
you are then done.
You will need to purchase a 2WD tail housing too.
This require the proper gaskets and O rings to seal up the tranny too.
Cheaper $$ would depend on many things here.
