Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700-R trans squeal
Old 02-06-2013, 02:58 PM
bsa_bob2's Avatar
bsa_bob2 bsa_bob2 is offline
700-R trans squeal
My trans has a squeal when it is backing up ..if you give it the gas. It sounds has a hi-pitched..dry sound. it never does this,with the kar in reverse backing up slowly.Its only when you try to back up the kar abit faster ,It then starts the squealing sound. I had a guy put a input bearing in the trans, in the kar,years ago. Is this the right name for it. Its the pump bearing ,it has to be mounted just right before engaging the torque converter squarely. Hope this made sense i remember he thru out a shim and said it wasn't necessary. it gets quite loud, the more you give it the gas in reverse.what do you think?
i've never bothered to repair it cause i don't back up much. and don't drive the kar as much as i used too,> bob s
