Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700-R trans squeal
Old 02-20-2013, 07:56 PM
bsa_bob2's Avatar
bsa_bob2 bsa_bob2 is offline
Originally Posted by rick 427 View Post
The trans definitely has to come out and apart,sorry to say....if I didn't see a stripped pump stator shaft spline while removing the converter,it wouldn't suprise me if I found a worn out low-reverse sprag in there. If just a few of the springs in that sprag assembly are worn/broken, it loses some of it's holding power,which could produce a screeching sound, under load, that you mentioned.It could very well be in another area,but without having it apart on my bench,all I can give you is a hunch.
I see you must work on these trans.Where are you at?Would you be interested in repairing the squeal? thank you for anything
