700 r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 03:23 PM
grapro's Avatar
Last journal entry: Out in the Sun
700 r4
Just installed a new tranny in my buddys coupe and when it shifts to second it wants to and sometimes kills the motor. Its a 700 r4 hooked up behind a 327. Tried a couple of settings on the detente cable seems to make a bit of difference but not quite sure of whats going on.
Old 03-28-2007, 04:10 PM
Not sure what you've got wrong, but watch out! If it is the the TV cable adjusted wrong, you'll burn it up quickly. Sounds like time to talk to the pros.
Old 03-28-2007, 06:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I am not sure how the trans would stall the engine while the vehicle is moving.
Does the car try to come to a stop or the engine shuts off and the car continues on forward?
Old 03-28-2007, 09:33 PM
grapro's Avatar
The motor stops it almost seems like when it shifts the motor is stopping like it is short of gas. has lots of power in first but doesn't seem to shift properly.
700 R4 won't shift all gm Transmission - Rearend 7 01-08-2007 05:32 PM
700 r4 to 8.8 driveshaft murrsue Transmission - Rearend 12 10-23-2006 11:36 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
700 r4 lock up kits murrsue Transmission - Rearend 8 10-07-2006 04:15 PM
700 R4 osw Transmission - Rearend 0 06-18-2006 04:47 PM
