700 R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2007, 01:18 PM
700 R4
My friend has a 1990 Gmc half ton four wheel drive with a 350 and 700r4 tranny. We were pulling out of the parts store and the truck was shifting from first to second and then made a clunking sound and stopped moving. It has no forward gears but reverse still works. The tranny wasnt in that great of shape to begin with and I was wondering if you guys think it will still be rebuildable. thanx
Old 07-03-2007, 08:55 PM
Crosley's Avatar
Wiki Edits: 1659
pull the trans out and have a qualified trans person inspect it.
700 R4 won't shift all gm Transmission - Rearend 7 01-08-2007 05:32 PM
700 r4 to 8.8 driveshaft murrsue Transmission - Rearend 12 10-23-2006 11:36 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
700 R4 osw Transmission - Rearend 0 06-18-2006 04:47 PM
700 r4 rebuild alf1096 Transmission - Rearend 1 06-17-2005 06:32 PM
