Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700-r4
Thread: 700-r4
Old 10-17-2006, 03:15 PM
briscoe briscoe is offline
checkball capsule in case,must seal to release band and at same time apply 3-4 clutchs so a leak here will take out 3-4 cl and or can replace capsule with a cup plug to seal this area,we do it at my shop on every 4l60,4l6o-e.also if you spin this motor up past 6000 rpms,doubt you do but you never know,but if you do the 3-4 clutchs can centrifuge on when they are not supposed to be on .this is caused by residual fluid under the clutch piston being forced outward and up against the piston dragging the 3-4 clutchs on.transgo makes a spring kit for this,heavier springs oppose this cetrifugal force.
