Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ?
Old 02-13-2011, 11:55 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
I don't think 87's used Electronic Speedos, so you'll need the signal generator parts from a 88up 1-Ton that came with the TH400.
Some Part # Info here>> http://www.turbobuick.com/forums/tra...sor-th400.html
Need to check Torque Converter mount pattern to see if your Flexplate will work.
http://www.transmissioncenter.net/sp...____va.htm#400
