Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ?
Old 02-14-2011, 09:43 PM
limp'n-gmc limp'n-gmc is offline
Those are cool . thanks
Originally Posted by SSedan64
I don't think 87's used Electronic Speedos, so you'll need the signal generator parts from a 88up 1-Ton that came with the TH400.
Some Part # Info here>> http://www.turbobuick.com/forums/tra...sor-th400.html
Need to check Torque Converter mount pattern to see if your Flexplate will work.
http://www.transmissioncenter.net/sp...____va.htm#400
Ok i got another if , so if i got one i found a 88 TH 400 or 89, 90 , whould that be a bolt and go, not to worried about flywheel as i will change it , but i may change pieces to get mounting it up done , i think if i can i would just prefer to get one from a 88 or that is already set up for my wiring harness ? whats your thoughts ? i really want to get rid of my 700 R4 , and put in th400, i think i would get some decent punch, my truck has 3.73 gears in the rear , so i wanna freak out my lady , she hates it aas it is , plus i dont need overdrive, its over-rated , LOL
