700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 11:45 PM
i have a tore up 700 r4 in my 88 gmc, i need to replace this i know , i have a location on a 400 turbo i would like to put in, but with the 400 coming out of a 87 454 , i have a 88 gmc 1500 w/ a 700 r4, will my speed o meter work with this ? My cruise ? i know i will need converter, but flywheel / flexplate ? will i have to make any changes ? or is it a plug and go ????? please tell me soon , cuz if it will work i need to get the tranny before its gone in someone eles's ride !!!!!!!
Old 02-14-2011, 12:55 AM
SSedan64's Avatar
I don't think 87's used Electronic Speedos, so you'll need the signal generator parts from a 88up 1-Ton that came with the TH400.
Some Part # Info here>> http://www.turbobuick.com/forums/tra...sor-th400.html
Need to check Torque Converter mount pattern to see if your Flexplate will work.
http://www.transmissioncenter.net/sp...____va.htm#400
Old 02-14-2011, 05:46 AM
If its a 4x4 you'll have to change the transfer case to one from a manual truck...unless spline count changed on the th400s in 88.
Shane
Old 02-14-2011, 10:43 PM
Those are cool . thanks
Ok i got another if , so if i got one i found a 88 TH 400 or 89, 90 , whould that be a bolt and go, not to worried about flywheel as i will change it , but i may change pieces to get mounting it up done , i think if i can i would just prefer to get one from a 88 or that is already set up for my wiring harness ? whats your thoughts ? i really want to get rid of my 700 R4 , and put in th400, i think i would get some decent punch, my truck has 3.73 gears in the rear , so i wanna freak out my lady , she hates it aas it is , plus i dont need overdrive, its over-rated , LOL
Old 02-15-2011, 01:24 PM
anyone got a tip
anyone got any ideas on this ?
Old 02-15-2011, 07:52 PM
what year 400 turbo, or truck to look for?
I am in the middle of dealing with the wore out 700 R4 in my 88 gmc swb 1500. I have always been a lead foot , i used to have a 70 el camino, but it had a 400 th in it , I loved how it worked , anyway i wonder what year or what truck would i look for to find a 400 TH that will work with my speedometer, or is my best bet to hunt for a electic after market kit that will make my speed-o work . Tickits suck LOL , any help would be greatly appreciated, i have 3.73 gears and a 5.7, so i am thinking the 400 would give me a good jump..... ????????? or is a 700 R4 strong enough to accept a stall converter ?
Old 02-15-2011, 08:58 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the t-400 short tail housing trans is a slight different length than the 700 trans.
T-400 trans mount will be slightly different location
The t-400 most likely will have a 32 spline out put shaft.. the 700 trans has a 27 spline out put shaft.
the speed-O stuff was addressed by an earlier post
350 turbo tranny leak Wildwestshow Transmission - Rearend 9 11-24-2010 07:27 PM
Turbo 350 tranny Babyburr Transmission - Rearend 3 09-12-2010 01:43 AM
350 Turbo tranny Questions cheyvman_1500 Transmission - Rearend 3 06-03-2010 04:57 PM
TURBO 350 Tranny How Many quarts?? 40forddgc Transmission - Rearend 1 11-28-2009 06:12 PM
350 turbo tranny / first gear badriand Transmission - Rearend 3 10-12-2007 09:42 AM
