700 R4 Build-up Help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2006, 05:31 PM
chrisape's Avatar
Let me start out first by saying HI to everyone here!
My project is a 1959 Chevy 3100 truck- 454 MPFI Vortec engine, backed with a 89, 700R4 tranny.
Well, to make a long story short, this is the second time I have pulled the tranny out! This is my first trans rebuild(with some help from a friend), Needless to say I missed a few check balls the first time, second time I figured out that the TV boost valve was only .365 dia., causing LOW boost and smoking the band and 3-4 clutch pack.
Now I have ordered the Z-pak, 1-2 & 3-4 pinless accumulators with heavy springs, 4th Super servo, 2nd Corvette servo, The Beast sun shell, and Raybestos clutch packs. The pump is being rebuilt with 10 vane impeller, .500 boost valve and new spring.
I have a question about the ball capsule that is installed in the case near the servo. I have read a few tricks that say to put a .385 plug in there and remove the check capsule. I have also read that it should be replaced with a new capsule. Does anybody have the best idea for this? I understand a leak here causes 3-4 slipping.
Thanks for any help!
Chris
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 01:48 PM
700 build update Jmark Transmission - Rearend 7 05-31-2006 10:35 AM
700 R4 (whats that smell) slick Transmission - Rearend 1 09-08-2002 08:23 AM
700 r4 vs 400 turbo? WBhunter Transmission - Rearend 3 04-23-2002 08:05 AM
