700 r4 eractic shifts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2006, 10:03 PM
i put a 700r4 in my 59 elcamino .it seems like it is shifting back and forth between 3 and 4 for a bit untill i get to a higher rpm .the lower gears shift fine .i canput it manually from 3 to4 and it does fine i put a it is all wired correctly and the vacume switch kit from tci in it for the torque converter solonoid the tranny was used and i do not kniow the histroy of it does any one have any hints the tv cable is adjusted right i belive hooked it up to the carb and released the tab and set the slide to pull the cable .i have the vacume line connected to a tee coming off the manifold .help ??????
Old 07-11-2006, 11:12 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
When you depressed the TV cable tab did you take the throttle to WOT?
Success is getting what you want but happyness is liking what you get.
700 R4 won't shift all gm Transmission - Rearend 7 01-08-2007 05:32 PM
700 r4 trans would not go-fixed now hotrodjohn Transmission - Rearend 0 06-01-2005 08:46 PM
Raptor 700 r4 JOHND. Transmission - Rearend 2 01-21-2004 09:55 PM
700 R4 shifting hard jpd37 Transmission - Rearend 8 09-22-2003 03:49 PM
700 R4 chrisf67 Transmission - Rearend 7 03-05-2003 06:03 PM
