700 r4 and lockup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2005, 12:10 AM
700 r4 and lockup
quick question
my 700 r4 has the full manual reverse valve body from TCI and the tci computerless lockup. is there a difference between stall and lockup on these.. my converter is a 2800 stall so does that mean driving down the highway in 4th the converter will not lock up or is that when the lockup kit comes into play.
Old 06-04-2005, 02:44 PM
sedan delivery's Avatar
lock up
the lock up kit lets the trans lock up the converter automatically, without the use of a computer. when the converter is locked up it is a solid connection between the flywheel and the drive shaft .. just like a manual transmission. the stall part of the converter is only in non lock up .
Raptor / Raptor jr 700R4 bootshd Transmission - Rearend 8 12-01-2004 05:39 PM
700 R4 4th gear problem. JOHND. Transmission - Rearend 0 02-04-2004 02:04 PM
Strange 200 R4 troubles joeyg329 Transmission - Rearend 3 12-11-2003 07:33 PM
