Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700-R4 no 3-4 please help.
Old 12-01-2003, 06:53 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Cool
MAny things cause the 3/4 pack to wear out .
The shop could be over looking a loose input shaft into the aluminum drum.
Bad sealing ring surface in the stator support.
Worn out boost valves, weak PR spring.
bad TV cable adjustment.... it is adjusted correctly??
It appears they are not correcting the problem with the 3/4 frictions.
