700 r4 problem
i have a 700 r4 it shifts fine in reverse but i forward you have to give it gas before it will go in gear and when it does it lunges forward any ideas what this could be
Its a recent rebuild
there is a pressure loss in the forward clutch section.
Possible problem in the input drum or the sealing rings or a cut lip seal or too much clutch pack clearance. A pressure gauge attached to the main line port may reveal a problem if the pressure drops off when the trans is placed into "D"
At the Bonneville Salt Flats, first gear is known as 130 mph. |
thnks ill hook up and check the pressure thnks for your help will let you know
what i find |
i would suggest starting with easy fixes like checking line pressure and ensuring the throttle cable is connected and properly adjusted.on a 700r4 the throttle cable is the only input to the trans for throttle pressure,same as a 727 or 904 torqueflight.
being a transmission mechanic ive seen many mistery problems with easy fixes that are never found easy.you could have a cut seal when it was rebuild or a cut sealing ring a sticky valve or a bad/leaky valvebody.try checking throttle pressure and cable adjustment,then next would be cheap fix number 2 try some marvel mystery oil a small amount and a deadblow a couple times against the pan.if that doesnt free it up it may be a serious internal problem. |
I think I know where you have worked .Vince |
checked pressure last night have 20 psi at idle but will go to 60 psi at a 1000 rpm, checked in reverse and drive same pressures
Minimum--------Full P= N= R= O/D= D= 2= 1= Don't forget Parking Brake & wheel chocks. |
| 700 r shifting problem | Bullet05 | Transmission - Rearend | 6 | 07-14-2006 05:46 PM |
| thm 700 r4 4l60 | lawyernie | Introduce Yourself | 2 | 12-07-2004 03:36 PM |
| 700 r4 shift kit | NXS | Transmission - Rearend | 9 | 12-04-2004 10:34 AM |
| 700 R4 leaking at gear selector | 1 Day | Transmission - Rearend | 1 | 08-21-2004 07:40 AM |
| 700 R4 (whats that smell) | slick | Transmission - Rearend | 1 | 09-08-2002 08:23 AM |
