when you have first gear is the shifter in D or in 1? Because reverse and 1 both have an extra clutch wich may still be good , but the clutch will only apply in R or 1 not 2, 3 or D.
When I took the truck for a test drive, it was in D. Later that night, I put the rear of the truck on jack stands. I put it in 1st and ran it to 1500 rpm and it was fine. I then shifted to 2nd and ran it to 2000 rpm. As soon as it hit 2000 rpm it jumped back and forth from 2000 to 1000 rpm. I understand this to be somewhat normal because there was no load on the transmission. Any more thoughts or opinions would be appreciated. Thank you ChevelleGuy for your comment, I appreciate it.
hotrod48 |
Hotrod48,
How did you adjust the Throttle Valve Cable? It could be an easy fix if you did not adjust this cable correctly. Good Luck Scholman |
I have been told that a sprag gear could have broke. Is this a possibility? This may sound dumb, but could the servo cause this? I'm not sure on any of this, but I'm learning. Thanks for the help.
hotrod48 |
several things can be wrong.
The 1-2 accumilator could be leaking past the piston. The 2-4 servo may have a cut seal or miss installed one leaking pressure off to where it should not be. The RPM's jumping up and down while on jack stands should not happen.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Crosley, thanks for the help. Do you think my torque converter is gone? To fix the 1-2 accumulator, would that just be a new seal? The trans was built by a shop, so I assume the servo was installed correctly to have lasted this long.
When I broke my trans and rear end, I feel that the shock of the rear end breaking caused something in the trans to go. Does this sound right or could cause one of the problems you listed? I hope to drop the trans this weekend (This depends on my dad's schedule too). There is a slim possibility that it could be disassembled too (Very slight chance). Thank you and I appreciate the help. Any more is also greatly appreciated. hotrod48 |
| thm 700 r4 4l60 | lawyernie | Introduce Yourself | 2 | 12-07-2004 03:36 PM |
| 700 r4 shift kit | NXS | Transmission - Rearend | 9 | 12-04-2004 10:34 AM |
| Puzzling temperature problem on the hemi solved | Centerline | Engine | 2 | 11-26-2004 03:48 PM |
| 700 R4 leaking at gear selector | 1 Day | Transmission - Rearend | 1 | 08-21-2004 07:40 AM |
| 700 R4 (whats that smell) | slick | Transmission - Rearend | 1 | 09-08-2002 08:23 AM |
