700-r4 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 05:09 PM
cardaddyo's Avatar
always the hard way...
700-r4 question
is there a simple one-man way to seperate a 700-r4 from a 4.3? heres where im at:all bolts are removed (6 right?)the engine is on a hoist and i have about a 3/4 to an 1" of seperation all the way around.where do or should i go from here? thanks in advance.
Old 09-24-2006, 05:17 PM
You're not trying to pull the trans with the torque converter still attached to the flex plate, are you?
Bob
Old 09-24-2006, 05:26 PM
cardaddyo's Avatar
awwwwwwwwww ****,ok ,regroup,what do i need to do? or have i already screwed the pooch?
Old 09-24-2006, 06:00 PM
cardaddyo's Avatar
can i access the torque converter to flex plate bolts from the panel on the bottom? it appears so,just want to be sure.i am gonna have to turn the tranny upside down arent i ?
Old 09-24-2006, 10:08 PM
The torque converter attaches to the flexplate with three bolts. With the dust cover /pan off the trans, you can reach them from the bottom. Rotate the crank until you get them all. You'll need to shove the converter back onto the trans so it doesn't fall off when you pull the trans off. When you reinstall, make sure the notches in the converter snout engage the tangs on trans pumps or the trans will not pull completely up to the block.
Bob
Old 09-25-2006, 12:07 AM
cardaddyo's Avatar
thank you for your help,you saved me alot of time and headaches.
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
700 r4 eractic shifts mrtaz Transmission - Rearend 1 07-11-2006 12:12 PM
700 R4 osw Transmission - Rearend 0 06-18-2006 05:47 PM
700 R4 chrisf67 Transmission - Rearend 7 03-05-2003 07:03 PM
