700 R4 shifting hard - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2003, 07:05 AM
I recently acquired a 92 Chevy 1500 pickup w/ a 350 cid and a 700 R4 trans. The trans shifts hard into second and I'm wondering if this is normal. I have a friend who tells me hard shifts are much better than soft shifts. I have also noticed it will not shift into second when it is cold until the rpm's get to about 1500. Does this sound normal?
Old 09-17-2003, 08:35 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you need to check the TV cable adjustment. MAy be pulling tooo much as you describe shift points in the 1-2 shift.
Hard shifts in a 700 are not good on parts.
Old 09-17-2003, 04:41 PM
I have checked the TV cable and it has no free play in it but it is not under tension when at rest. I will increase the slack a bit to see if it improves the shift. Thanks for the tip.
Old 09-17-2003, 07:24 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
there is trouble IF there is no tension on the cable when the throttle is closed. The TV cable should have slight tension, not loose like a T-350 cable.
With a 700/4L60 tranny there is a minimum setting or the trqanny will go into failsafe mode if the check ball is in the valve body. It will then shift late and quite firm.
I assume the truck is still EFi throttle body.
Perhaps the cable is damaged and stuck. Linkage inside the tranny stuck , broken , damaged?
Old 09-18-2003, 12:05 PM
When I bought th e truck, the previous Owner told me he had GM replace the trans about a year ago because the original trans failed while towing his rod on a trailer. He added a trans cooler when the replacement trans was installed. I have checked the linkage and cables and all is working smoothly without binding or unusual stiffness. I have checked the fluid and it has good color and does not smell burnt.
Sounds like a teardown would be necessary to inspect the check ball in the valve body.
The carb is a simple, original two barrel.
Maybe it is natural to shift like it does. I am going to try to find a couple similar trucks and drive them to see how they shift.
Old 09-18-2003, 08:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
A 1992 Gm truck would not have a 2 barrel carb on it. Should be a throttle body injection setup which appears like to a 2 barrel to non automotive folks.
So I am a bit confused at this point.
Old 09-19-2003, 09:39 PM
Drive that vehicle a little and experiment with the TV cable like the rest has mentioned. That TV cable is touchy.....1/16 of an inch off is completely different tranny.
Is there a shift kit in there?
I put a shift kit in my 700R4 and it holds the shifts when working properly under throttle. Part throttle it does not hold the shifts.
Old 09-22-2003, 12:18 PM
To my knowledge the trans does not have a shift kit.
Interesting about the carb. I pulled the air cleaner to look atthe linkage, and simply glanced at the carb. It looked like a two barrel but because I don't tinker with cars often, I could have been easily fooled.
I will slacken the tension on the TV cable as you suggest (max 1/16" incriments) and see if there is any improvement. I'm thinking that might do the trick, since it tends to down shift very frequently with the touch of the throttle.
Old 09-22-2003, 04:49 PM
Mrfixmaster's Avatar
Last journal entry: Red, my second T--Bucket
I have a 1988 305 with the 700R4 in my T-Bucket. I used the information at this website to set up my TV Cable, and have had real good results. I am even able to "slack-off, or tighten-up" the cable one or two clicks to adjust it to the conditions, cruisin, or stop-lighting.
http://purplesagetradingpost.com/sum...o/700R4p1.html
MF
