700 R4 tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2006, 11:05 AM
700 R4 tranny
There is a local guy who has a 700r4 mid 80's tansmission for sale.
It was rebuit 10,000 mi ago and has the torque converter with it.
He wants $200 I fill that this is a good price?
Anyway I have a T400 in my 49 chevy pickup now that I want to replace it with. Is the bell housing the same size. I have only 1/4 inch of space
between the tranny and the body now. If the bell housing is
bigger on the 700r4 it won't work.
If I remember i will need to shorten my drive shart too. Is that correct?
Mark.
Old 10-01-2006, 06:03 PM
48ChryslerRodder's Avatar
Stuck in the past.
I have this picture with dimensions for gm transmissions, I hope this can help you.
Old 10-01-2006, 07:30 PM
Tbucit's Avatar
Last journal entry: Kinda showing off
You will need to move your crossmember the 700R4 is about 6 inches shorter. There is a talpiece I am tying to get that gets it closer. The bellhousing area is very close to the 400
Randall
Old 10-01-2006, 11:59 PM
68novafan's Avatar
Ford Fan At Heart
isnt the 700r4 computer controlled? and youll need to make previsions for the TV cable.
Old 10-02-2006, 07:14 PM
I think they made 2 different length on the tail end of the 400 I have the shorter one. According to the guy i am buying this off, the 700 R4 is 2 inches shorter than my 400 with the short tail stock.
Old 10-02-2006, 07:44 PM
Tbucit's Avatar
The guy is wrong look at the dimensions of the earlier post there is almost 6 inches different. The mount is on the main body of the 700R4. There is a different tail peice that will get you closer. And no the 700R4 is not computer controlled but the 4L60E is. It does use a lock up convertor
Randall
Old 10-08-2006, 10:44 AM
LordMaximo's Avatar
Last journal entry: Painting
You should get the fly-wheel, torque converter, cable setup, all with the transmission. This is a combination package and should not be seperated unless you already have the acessories. Ther is an after market device you will need to acquire for the transmission to work properly, it works off the speed sensor to engage the proper OD shifting point for locking up the transmission. Check out; http://www.ronfrincis.com for the lock up kit.
Takes less then an hour to install, less then $200.00, but worth it.
700 R4 won't shift all gm Transmission - Rearend 7 01-08-2007 06:32 PM
700 r4 question mychevystang Transmission - Rearend 5 12-06-2004 07:09 AM
truck 700 R4 computer controlled?? Ridr Transmission - Rearend 2 07-09-2003 05:53 PM
700 r4 tranny lumpie Transmission - Rearend 1 03-19-2003 05:45 PM
700 r4 vs 400 turbo? WBhunter Transmission - Rearend 3 04-23-2002 09:05 AM
