700 r4 trans would not go-fixed now - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2005, 09:46 PM
Thanks for all the ideas-if you remember I had a 700 r4 that would not turn the wheels - it was built by a trans shop, and had been taken back at least once but would not spin the wheels at any rpm-well, finally I took it to another shop where we had known the owners from Drag Racing, and they took trans apart and said a valve was in backwards-so all works well now-the shop that solved the problem is super - it's Golden Gate Transmission on Old Santa Rita Road in Pleasanton, California -- They did an excellent job- Hot Rod John
700 R4 won't shift all gm Transmission - Rearend 7 01-08-2007 06:32 PM
700 r4 question mychevystang Transmission - Rearend 5 12-06-2004 07:09 AM
700 R4 4th gear problem. JOHND. Transmission - Rearend 0 02-04-2004 02:04 PM
700 R4 shifting hard jpd37 Transmission - Rearend 8 09-22-2003 04:49 PM
want to change from 200 to 700 trans. lanierledford Transmission - Rearend 2 08-26-2003 08:25 PM
