700 rebuild progress and questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2006, 06:48 PM
Jmark's Avatar
Well, got bored today, real bored! Decided to pull the 700 down for a look see. I don't have any of the new parts yet but am getting close. So far, no big damage anywere that i've been able to find. Pulled all clutches out and only found two frictions that were "coned" and worn down on the edges, they came from the first stack in the input drum. Steels had hot spots too.
All the rest of the clutchs looked great, as did the band. Planets feel nice and snug, but am going to use a feeler guage and check the play. Sprags work good and I pulled them apart far enough to check the springs, none broken. All in all, the whole trans looks good.
But I need a few questions answered please. (waiting on a rebuild video)
Should I change the sprags anyway? Or re-use them? Any good test for them?
I'm wanting to change out all the torrington bearings and notice there is one inside the rear planet. I've tried to gently get it out but it doesn't want to clear the 4 small gears. Does it come out? or is it a non service item that comes with a new planet only?
I noticed what looks like a small scratch or nick or casting flaw on the housing right were the pump o-ring seats. The trans was dry and doesn't show any signs of leaking, but i'm wondering if a little rub with some 400wd would work to smooth it out some. It may not even be an issue, but I'm curious. Here is a pic.
Thanks for any help.
Mark
Old 02-04-2006, 08:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
looks better than this 4L65e unit...all the pictured parts are broken . Drive shell ( beast) is trapped by shaft wedged into the inner sun gear.
parts from a Caddy AWD with super charged 6.0 liter
At least replace the FWD sprag that is the aluminum drum. Good insurance IMHO
The inner torrington in the rear planet will not come out with removing the pinion gears. Check it for operational smoothness with fingers or sun gear.
Smooth the nicked area out with sand paper cloth
Old 02-04-2006, 09:01 PM
Jmark's Avatar
Hi Crosley.
Man, thats gotta hurt! LOL Glad mine is in better shape! How in the world does one snap the shaft?
Some how I think i'll be making a few "purchases" on Monday with my wifes card. LOL Can't stand seeing all my parts sitting there.
I'll add the sprag to my list of goodies. Can't wait to "get-er-done"!!
May have to build one for my '86 truck too. Its a real gas hog with the th400 and 4.11 gears! Its heavy though, 3/4 ton with a big cabover camper. Sure could use to slow the r's down some on the freeway. Just hate shelving the 400 trans, truck only has 32,000 on it.
My wifes '86 Caprice has a 700 also. Got 72,000 miles on it now. Might be a good idea to build one for a backup while i'm at it! LOL
Old 02-04-2006, 10:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
super charged 6.0 motor, 5.3 will do the same
Gear vendors..... best option with heavy weight
Old 02-05-2006, 05:25 PM
Jmark's Avatar
Well, i'm kinda confused on something.
Today I was taking the input shaft/drum apart and got all the way down to the apply piston. Inside the end of the shaft there is a brown bushing. Under that bushing was a small brown plastic piece that I first thought was a snap ring. On closer inspection, it appears to be from the bushing. Was there something else inside the bushing, like needle bearings? Or not? Is it just broken? Will the rebuild kit have a new one?
Second question. I understand that that same apply piston engages the next two stacks of frictions and steels, the ones on the sprag. (small ID and larger ID.)
Then comes a snap ring, then starts a larger stack of frictions and steels. On mine, these were the ones that had the two coned and worn off frictions and all the steels have hot spots. What I don't understand and cannot figure out is what "applies" that pack? I don't see any way that the apply piston way down inside can apply them as the two sets are divided by the snap ring inside the drum.
The outermost pressure plate pushes against the 5 sets of small springs on the inside edge of the drum and has the big snap ring holding it in. I see nothing on that end that could apply the pressure plate either. Someone enlighten me please! LOL
I think it just came to me. That pack is applied by the 5 long black tabs that run down the inside edge of the drum? They are moved by the same piston that applies the two inside packs that are on the sprag? Are there two pistons in there together that apply independent of each other giving a different throw for each pack?
On looking at the gap on that stack to the outermost pressure plate, its got to be close to a 1/4" also. ( old frictions and steels are still in it) Is this even close to being right? Or is something way wrong.
Lastly, when I took the snap ring off the output shaft yesterday, the "pain in the butt" one down inside the planet, the entire output shaft came out the back of the tranny. Is this normal? Seems that my TH350 came out from the inside. Or am I just really tired and need a nap? Seems kinda scary that one little clip keeps the output shaft from shooting out the tail housing and distroying the tranny.
Thanks again for any help.
Mark
confused in Phoenix
Old 02-05-2006, 05:56 PM
302 Z28's Avatar
You might be waiting a while, my 90 model has 147,000 on it and it still performs like new. Of course it has been serviced a few times.
Vince
Old 02-05-2006, 05:59 PM
302 Z28's Avatar
I second that, a fellow club member who has a hotrod 48 Ford bus with a big block Chevy has a 400 turbo with a Gear Vendors overdrive and loves it.
Vince
Old 02-05-2006, 08:20 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you need a good tranny book on the 700.
find one , read it twice then proceed.
Old 02-05-2006, 08:44 PM
Jmark's Avatar
LOL@Crosley!
I know, I know, too many questions. Its just that its all over my saw table and i'm still waiting on my ATSG manual and video. Was hoping they would have been here Saturday, but no such luck. I'll go put it all away and wait it out, got to finish a 9' wide Cherry cabinet and bookcase anyways. Not enough room for both in the same shop.
Mark
Old 02-06-2006, 02:46 AM
>Rebuild kit comes with a new one.
The 3/4 clutch pack (the thing you removed first) is operated by the 5 fingers around the edge that you see.
Details on my rebuild, including how to make your own diy tools for this transmission can be found here:
http://www.mez.co.uk/Chevy700r4pg3.html
Eliot.
Old 02-06-2006, 03:25 AM
While not nearly as informative as the site eliotmansfield has you may find some helpful pics Ive taken that pertain to the 700 at the following link:
http://www.turbotimelounge.us/gallery/myclone?page=1
(BTW, you'll need to scroll down some to find the 700 stuff since that site is where I dump all my misc pics that I take or find while browsing the interweb)
Old 02-06-2006, 10:13 AM
Jmark's Avatar
Elliot...
Thanks, I have your page in my favorites already! Just waiting on the book and CD (and $$$) so I can get cranking.
I was telling my wife about Crosleys reply last night. She got a good laugh. I tend to get a little excited on new projects and I can't imagine how many emails and PM's that he and Airworld must get in a day. But I like learning new things, specially things that I shyed away from when I was younger, like dancing and trannys! LOL (interesting combonation huh?)
My wife and I started taking dancing lessons a few years ago. Payed off too, got to do some "real dancing" at our sons wedding. That was cool. We really "wow'd the crowd". (didn't take a whole lot either!)
Trannies are something i've always wanted to get into but never had the courage, until last year when I redid my engine and tranny in my truck. It was fun and quite an accomplishment.
Cylone.....
Good stuff! Love the Dually burnouts too!
Well, back to the sawmill
Old 02-06-2006, 05:19 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I still do not dance.
Old 02-06-2006, 05:33 PM
Jmark's Avatar
Tony,, you should try it sometime! Its fun, plus you'll make bookoo brownie points with your wife. The VFW at 48st and Thomas has Swing lessons every day of the week. 7 bucks a person, lots of fun. We took Waltz at Fred Astare and with our swing teacher. Kinda hoping someday to get on "Dancing with the stars!" LOL
Anyways, mail dude just came by, still no book or video. Crap!!! I need to get after it before I forget where everthing goes.
Old 02-07-2006, 10:19 AM
Jmark's Avatar
Crap! Book and video were mailed YESTERDAY!! Won't be here for 3 or 4 days. Oh well, might be a blessing anyways, looks like my wife may loose her job this week. Glad I didn't go buy all the parts yesterday!
Mark
Progress update on the '27 T Nightfire Hotrodders' Lounge 7 10-28-2005 02:33 PM
ANSWERS TO COMMON QUESTIONS -- PLEASE READ BEFORE POSTING Jon Hotrodders Site Suggestions and Help 0 07-07-2005 03:58 PM
72 Olds Cutlass Intake Questions Sparksfarm1 Engine 0 09-16-2004 07:03 AM
