$7000 to build 10 sec 351 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2010, 10:41 AM
prettyboyced's Avatar
I have 7 grand to build a ford 351 all motor I need it to rum low 10s I was looking at afr 1451 225cc and solid roller cam I need any help
Old 08-23-2010, 10:51 AM
delawarebill's Avatar
what car are u puttng it in???
the blue one looks like a camero, pic is small... but an option for u.. a bbf 460ci.. tons of torque.. and if u go to "gearz" tv show from last sunday there was a place u can get some really nice upgrades for that motor and get major HP... if u thinking of using a mustang 2... that motor will fit.. as long as u have a BFH....
Old 08-23-2010, 11:13 AM
It's for a class in we have 10000 to build a 10 sec race car max cube inch is 360
Old 08-23-2010, 12:13 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
owch!!!
i was going to say stroke it and use a ton of compression leaning towards 114-116 octane.
i hate NO2 but are you guys allowed to use nitrous if so then that is what i would build for, a decent 2 stage with around 200-300 shot on each.
bulding a low 10 sec small block whether it be ford, chevy, or mopar is not going to be easy without a ton of compression or a ton of NO2
Old 08-23-2010, 12:35 PM
GTXKen's Avatar
what about the chassis? What does it weigh? Costs a lot less to make 2700lb do 10s then it does to make 3700lbs do 10s
Old 08-23-2010, 12:36 PM
The max no2 is 150
Old 08-23-2010, 12:44 PM
It's a 1994 mustang
Old 08-23-2010, 12:49 PM
GTXKen's Avatar
Do a search and find the thread about lightening the car and do every one of those tricks, pulling stuff off the car and drillings holes in bumper brackets is cheap speed.
Old 08-23-2010, 12:53 PM
my87Z's Avatar
X2
then i would look into a 13:1+ motor
Old 08-23-2010, 01:10 PM
GTXKen's Avatar
Originally Posted by my87Z
X2
Good point, thats old school fast, big compression, big cam and race gas. Nobody said it has to be street friendly
Last edited by GTXKen; 08-23-2010 at 01:11 PM. Reason: because I can't spell/type!
Old 08-23-2010, 01:14 PM
Can I do it with less the 10 grand
Old 08-23-2010, 01:54 PM
ericnova72's Avatar
More for Less Racer
$10,000 in just the engine?? Yes you can, easily. 10 grand in car with engine and driveline will ba a little tougher, you will have to hunt Craiglist, etc for bargains on some stuff.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
planning the 10 bolt build up elcaminodragster Transmission - Rearend 4 11-28-2008 01:04 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
351 c build up will4202 Engine 1 01-05-2006 11:13 AM
cheapest 351 w build 82c10 Engine 1 06-14-2005 10:04 AM
