7004R transmission conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2002, 04:34 PM
Post 7004R transmission conversion
need help in how to get a 7004R trans to downshift without computer. Will not change gears and stays in high gear.
Old 11-02-2002, 04:38 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Contact http://www.bowtieoverdrives.com/
Old 11-02-2002, 05:12 PM
BOBCRMAN@aol.com's Avatar
Post
sounds like you have a convertor clutch not releasing, most of the kits sold are to lock up the convertor, the shifts are regulated by the tv cable and road speed.
Old 11-03-2002, 02:38 AM
deuce_454's Avatar
Post
ditto to willys, ive ordered a stage 3 700r4 from them and the service is outstanding and product is really good
Old 11-03-2002, 02:44 PM
Post
Transmission is out of a '93 model chevy pu. with a computer...with 10 prong wireing on the side. I need to know how tomake in a'86 pu. with 454 with no computer.
Old 11-22-2002, 05:40 AM
Post
I am not a pro, but I had thought that in 92 and 93, maybe newer that they started putting in the 4L60-E tranny which is hooked into the ECM, I just noticed it on the truck I bought, if I figure anything out I will be sure to tell you too.
Old 11-22-2002, 11:27 AM
Post
Your going to need a computer to get it to work. Either go to Willys' site or dig around for a diesel computer aand loom and retrofit it. The new one is waaaaaaaay easier and will actually work when your done.
