700R 2wd or 4wd whats the difference??
I have a 1985 S-10 4x4 with a small block that needs a transmission. It currently has a 700R with no 3 or 4 gear. I know the cases are different, but will a trans for 2wd work? The reason I ask is because I found a B&M for a deal. But its 2wd.
Thanks Dave |
as Eliot posted.... the 2wd & 4x4 shafts are different lengths.
they are interchangable. You cannot cut a 2wd shaft down to the length of the 4x4 shaft.... there would be no splines .
At the Bonneville Salt Flats, first gear is known as 130 mph. |
small block powered S-10 4x4 vehicles do not have a lot of room to work with . The engine may be too far forward, oil pan issues on the front diff.... the list goes on
Thanks guys; that just saved me a bunch of money
. But somebody got a great deal on Ebay, B&M 700R4 trans, holeshot converter, and lock up switch with less than 1500 miles for $735.00. I wish I could have used it.Dave |
| 4wd to a 2wd.. frame info | 53fordguy | General Rodding Tech | 9 | 12-14-2004 05:03 AM |
| Difference between 150 & 210? | super_kev | Hotrodding Basics | 2 | 04-25-2004 05:53 PM |
| Chevelle Coversion to 700r using 86 camaro trans 700r | theroq | Transmission - Rearend | 0 | 02-08-2004 12:03 PM |
| 2WD TH350 to 4WD TH350 | rambo_z28 | Transmission - Rearend | 6 | 07-17-2003 05:17 PM |
| lifting a 2wd 77 chevy C10 | chevyman77cd | Suspension - Brakes - Steering | 2 | 12-24-2002 03:15 PM |
