Shifting at 10 MPH? What, at full throttle? Or at part throttle?
If at full, then either you have a 9:1 axle, or a diesel governor, or your TV cable is way out of adjustment, or your line pressure is far too high, probably due to the pressure regulator spring. If at part, then there's nothing wrong, but if you want it later, you should probably start with a stiffer spring for the pressure regulator. |
It's at 10 mph at part throttle .I have no idea what the trans came out of ...the outer weights are 41.5 grams the inneris 15.2 grams this is the one the spring hook to ..my gears or 3.73 with 26 inch tires and 24-2800 stall
the harder the spring tension, the earlier it will shift as where the lighter springs will bring the shifts up later. on the weights, the lighter the weights, the longer it will hold the shift where as the heavier weights will provide earlier heavy/ full throttle shifts. |
| 700R4 Govenor sticking | BrokenTruckGuy | Transmission - Rearend | 19 | 10-13-2011 06:51 AM |
| govenor | willis 77 | Transmission - Rearend | 1 | 08-06-2010 05:09 PM |
| govenor removal | THERACER | Transmission - Rearend | 9 | 10-20-2008 01:31 PM |
| Chevelle Coversion to 700r using 86 camaro trans 700r | theroq | Transmission - Rearend | 0 | 02-08-2004 12:03 PM |
| Finding my govenor | Dreadlord | General Rodding Tech | 8 | 12-02-2003 02:35 PM |
