700r 4 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2009, 12:22 AM
700r 4 transmission
shifts fine in 2nd, 3rd and overdrive, but will not shift out of 1st until extremely high rpms, have adjusted the throttle cable, no help, replaced transmission filter no help, wired the voltage to the torque converter no help. whats my problem?
THANKS!!!
Old 09-28-2009, 09:20 AM
Barn Owl's Avatar
Have you checked the fluid level? how old is the tranny?
How are you adjusting the t.v cable.
Pull the release clip, pull the cable out tight, then open the throttle all the way and while its open reattach the retaining clip.
Try this thread, 700R4 trouble
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 03:50 PM
700r Transmission wyndian Transmission - Rearend 3 05-08-2008 01:58 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
700r transmission problem mjhendrix Transmission - Rearend 3 09-14-2003 07:46 PM
