700r adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2006, 12:33 PM
700r adjustment
I just finished my 1960 jag with a 700r Tanny. I am having difficulty setting the adjustment on the cable . Is there e a simple way to do this
Old 02-04-2006, 06:41 PM
Ensure throttle cable pulls throttle blades wide open first.
After assuring this, at WOT the TV cable must be pulled taught; ie NO more TV cable travel at WOT.
Ratios and distance from throttle blades do affect TV cable initial setting.
You may want to use a pressure gauge.
70-90 PSI at idle; 180-240 PSI at WOT setting. Pressure is dependent upon regulator spring and booster valves...
Old 02-04-2006, 06:46 PM
302 Z28's Avatar
The TV cable is adjustment is most important on this trans. If done improperly severe damage to the trans can result. It is also important that the correct ratio at the throttle is set. Holley as well as Edelbrock make a bolt on bracket that does this. I think other firms like Bowtie Overdrives, TCI, and Lokar also have the kits. What carb are you running on your car?
Vince
Old 02-05-2006, 05:58 AM
700r adjusment
I have a 650 Edelbrock cab, with a lokar cable. I have an end play of .070 set between the cable pull and carb.
Old 02-05-2006, 07:32 AM
Jmark's Avatar
The Edelbrock carb needs a linkage "fix" for it to properly pull the TV on the 700. Its item #29 on this page. Don't leave home without it!
Mark
Old 02-08-2006, 06:03 AM
700r adjustment
Thanks for the info. I am purchasing kit to try .
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
wiring in a late model 700r tranny TooMany2count Transmission - Rearend 5 09-28-2003 07:00 AM
Best place to buy a rebuilt 700r tranny??? bg Transmission - Rearend 3 03-15-2003 01:51 PM
700r cable adjustment Seon Transmission - Rearend 3 12-05-2002 08:14 PM
