Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r failure
Thread: 700r failure
Old 03-18-2013, 08:48 AM
dwwl dwwl is online now
I would also bet that there is so much metal in everything that, that if you rebuild it, it just will cause you more problem later. So, buy a good use one, and use it, or rebuild it and use your old one for the parts you might need for the rebuild. I bought one used 200 r4 from a local guy of CRAIGS list for $75.00. One from a guy i knew for $75.00. Then I had a guy give me a bad one for parts. That bad one worked out great. I then had extra things to experiment with.
