700r fillter change - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2011, 07:38 AM
700r fillter change
How much fluid does it take to fill it back up .I'm not sure my dip stick is correct .it leaks fluid after its parked .so I want to make sure its not over full .it leaks from the servo cover I'm guessing its when the converter drains back. Thanks for any help
Old 12-16-2011, 01:40 PM
tnsmith10's Avatar
when will it rain???
on average, a 700 will take anywhere from 4 1/2-5 qts on a service.
as far as the leak goes its not typical for the leak to happen from converter drain back at the servo. more than likely its the filler tube, or the tv cable that is leaking from the converter drain back.
Old 12-16-2011, 05:00 PM
Thanks for the help . I will check it a little closer I hope its the dip stick .if it is the servo cover I will have to pull the trans.
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 12:32 PM
700r rednova350 Transmission - Rearend 1 09-14-2004 05:00 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 01:03 PM
700r help 85406 Transmission - Rearend 1 05-17-2003 08:33 PM
Won't change,wont' chang,won't change Samrupert Transmission - Rearend 6 01-11-2003 02:32 PM
