700r not going into overdrive - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2009, 01:52 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
my tranny not going into over drive. why not?
Old 03-02-2009, 03:30 PM
If you have all the other gears, usually one of two things
TV cable or valve stuck-usually will shift hard into each gear
Gov. stuck or gear is stripped.
700R4 or TH400 w/ overdrive 53LEDSLED Transmission - Rearend 8 05-28-2007 09:22 AM
saginaw 4 spd overdrive scatsihc Transmission - Rearend 0 02-05-2006 08:44 PM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 08:20 AM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 01:03 PM
Overdrive transmission merkery Transmission - Rearend 1 06-25-2002 10:25 PM
