700r overdrive unlock - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2009, 07:52 PM
48aero's Avatar
Last journal entry: 53 Chevy PU
I need to know if anyone knows of a hydraulic switch that I can put in my brake system to open the circuit when pressured up, that will disconnect the lock up converter circuit. What it boils down to is a switch that is normally closed and goes open when pressured up. Thanks Jesse ( preferably 1/8 pipe)
Old 09-09-2009, 08:01 PM
SSedan64's Avatar
The Brake light switch from an 80 up Chevy truck that used the TH350C trans would do what you need without tapping your Hydraulics. Trucks/Cars with the TH700R4 and Th2004R trans would work also as they used the same type Brake switch. I do remember reading in the Brake section a while back about someone using a Hydraulic switch in the Brake line for TCC disengagement also.
Old 09-09-2009, 08:07 PM
SSedan64's Avatar
These are Trans pressure switches, I think they're 1/4" NPT tho'.
Pressure Switch (NC, Two Terminal) GM#8642346
Pressure Switch (NC, Self-Grounding) GM#'s 8642569 or 8634475
http://www.gmpartsdirect.com/
Cruise Control Style Brake Switch GM# 5524845 Unlocks TCC when brakes are applied; also used as part of cruise control in some cases
Old 09-10-2009, 04:56 AM
48aero's Avatar
Thanks for the reply. I can't use the typical on the column switch because I'm building a 53 Chev pu with the pedal thru the floor. That's why I would like to find a hydraulic switch that I could plumb off my brake master to unlock the converter. It has to be a switch that is normally closed and goes open with pressure. I'll check out the switches you gave me part numbers for today. Any more info would be appreciated.
Old 09-13-2009, 06:23 AM
48aero's Avatar
Just thought I'd let you know I figured it out, for those who might have the same problem. I used a 5 pin relay. I connected pin 30 to batt, pin 87a to the trans feed, 85 to brakelight switch output, and 86 to ground. When the brakes are applied the relay switches to pin 87 and the circuit is broken, thus opening the trans feed. Note 30 and 87a are hot normally.
Old 09-13-2009, 07:51 AM
302 Z28's Avatar
It's been beat to death in this forum, the below example shows a mechanical switch, but the circuit is the same for a hydraulic pressure switch.
Vince
Old 09-13-2009, 09:07 AM
48aero's Avatar
I just couldn't find it, I wish I would have talked to you a week ago!! Thanks Jesse
Old 09-13-2009, 09:53 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
as a FYI....
I have posted the image of the wire diagram of 700r4 converter lock up diagram as a "sticky" at the top of the forum here.
this question is asked many times.
I thank you guys for this information and image .
I started a WIKI page for this subject:
WIKI PAGE
lets build this page of WIKI to something we can link to and answer these type of questions for members
700r not going into overdrive American Muscle Transmission - Rearend 1 03-02-2009 02:30 PM
Tuck & Roll Upholstery Mother Interior 17 09-23-2008 08:44 PM
saginaw 4 spd overdrive scatsihc Transmission - Rearend 0 02-05-2006 07:44 PM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 07:20 AM
Overdrive transmission merkery Transmission - Rearend 1 06-25-2002 09:25 PM
