700R Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2005, 03:33 PM
my350camaro84's Avatar
Smoke Tires, Not Drugs.
700R Problem
Okay, I'll be perfectly honest, I'm at my wits end with this damn transmission. I have the 84' Camaro. I need to figure out whats going on with this. when I floor it the car jumps and goes but wont shift! I've adjusted the kickdown 10 million different ways and no change. but it's only when it's all the way to the floor, it will just hold at like 5200 or something like that. I've tried letting off then on and sometimes it will shift. I've been told it's a lockup selnoid but before I go into doing that and the filter kit I wanna make sure thats the problem. Please help me out here. I'm going nuts.
Old 06-09-2005, 06:00 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
So the tranny up shifts and down shifts fine under light - moderate throttle?
usually a mismatch of the governor and valve body springs cause this.
Lock up Solenoid has nothing to do with shifts
I'd pull the governor and check the style of weights and tension of springs.
Since you know little about an automatic tranny find someone that has some knowledge is the best idea I can give at this point
Old 06-09-2005, 07:36 PM
yeah, I'd figured someone would give me a reply like that. Well I guess I'll just live with it, it can't screw up the Trans any can it? it's just got to last me for about a month from now then I'm converting it over to a T-5.
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
*&%##*^#!! starter problem solved!!!! 85 vette Engine 12 02-22-2005 08:12 AM
700R questions club327 Transmission - Rearend 4 02-14-2005 10:27 PM
Newest Transmission problem RObs71Nova Transmission - Rearend 4 01-30-2005 07:00 AM
Piston/valve interference problem jameskirk1 Engine 12 12-03-2004 04:14 PM
