700R QJet vs 350 Qjet Detent
Ok, well I recently did a head job on my 85' K10, got it all buttoned up and I'm currently playing with the tuning. Anyhow, the carb I used was one from my other truck, a C10 with a TH350, where the K10 has a 700R4. Anyhow, so my TV cable is different now compared to the one that was on the C10.
What're my options to fix this? The 700R cable goes WAY past the hookup on the carb and is a long oblong loop where the 350 one was a black snap. I couldn't probably snag a 700R QJet from a junkyard if this is too hard to remedy... Last edited by Gokussj5okazu; 03-24-2010 at 12:38 AM. |
I know I can buy/modify the bracket to produce the movement angle that the 700 needs, but I'm stumped on the cable end, I've never seen one like it and I can't quite figure out how it will hookup and be adjustable once I modify the bracket.
It's got an end like this one but about an inch longer slot..
If you find the cable slot is too long to provide the correct adjustment at closed throttle (usually, the cable is under some small amount of tension at idle position, IIRC), a small machine screw and nut can be attached through the slot and loctited in place to provide the stop- this will in effect shorten the slot. |
Thanks! I knew it'd be something ridiculously simple like that...
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| 700r to turbo 350 speedo | flips65 | Transmission - Rearend | 2 | 01-14-2010 12:50 PM |
| 348 or 350 delimma | 62ImpalaSS | Engine | 12 | 05-17-2006 11:03 PM |
| 700R to 350 | JH30906 | Transmission - Rearend | 9 | 10-05-2005 07:17 PM |
