700r question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2012, 08:44 PM
Prof. T. Soggmeyer's Avatar
Plan B
700r question...
In regards to 27 or 30 spline, I have read that you count the middle spline and I have read that you count the little one down in there. Can someone clarify this?
Brad...aka..soggy
Old 04-15-2012, 02:48 AM
Wiki Edits: 85
You count the input splines.
Old 04-15-2012, 06:55 AM
Plan B
I'm sorry, I forgot to mention in reference to being able to id a converter for a 700r.
Brad...
Old 04-16-2012, 08:30 AM
SSedan64's Avatar
In the Converter it will be the Turbine splines in the bottom which turn the Input/Turbine Shaft in the Trans
The splines in the middle fit the Stator Support on the Trans.
Converter components >> http://www.tciauto.com/tc/tq-explained
Old 04-16-2012, 09:03 AM
Plan B
Thanks, my knowledge of automatics is very limited and it shows, that page is great! It really helped alot, now I know what I am looking at.
Brad...
Old 04-16-2012, 03:48 PM
Plan B
I am going to put my new converter on (30 spline), and see if that fixes my problem. This trans wouldn't budge, it shifts easy, the tv cable is set right, new filter, tcc lockup kit installed. No matter what gear it's in I get nothing. The pump filled the converter, oil filter, and cooler. Well I hope it's the converter because "here goes" in with the new one.
Brad...
700R question vanislander Transmission - Rearend 8 02-05-2010 07:30 AM
TH-700R Question fredbaker Transmission - Rearend 5 08-26-2009 08:21 PM
Simple 700r question 69 SS elky Transmission - Rearend 1 08-18-2009 07:48 PM
700r question 03eiger Transmission - Rearend 2 12-02-2007 09:39 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
