700R Shifting Hard and Late - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2010, 09:41 PM
Gokussj5okazu's Avatar
Last journal entry: 336 Stroker: Teardown
Coupled with my smoking engine, I'm having a tad bit of transmission trouble, but not as bad.
I've got a custom TV cable bracket setup on my Q-Jet, pulling good 78*, so I know that's right. At WOT, I connected the TV cable at full pull. However, I'm getting late, slow, hard shifts. Pretty much, I can get it to shift 1-2 at 35 hammering it, but at partial throttle and 20, it takes a good 5 seconds of steady throttle for it to shift. Either way it's hard and actually cause my u-joints to complain a bit.
2-3's pretty much the same, but ALOT smoother.
I'm thinking I need to adjust the cable, but I'm not sure which way to go. Also, how tight should the cable be? Like, how hard should it be to pull. Mine's VERY easy and loose, almost like it's not even connected...
Old 04-02-2010, 04:54 AM
tnsmith10's Avatar
when will it rain???
the cable must be tight at wot for the trans to work right.
Old 04-02-2010, 09:22 AM
Ya, I've got that adjusted correctly, all out at WOT, but I mean pulling on the cable itself is very easy, its really loose feeling like it's not pulling on anything in the trans.
Old 04-02-2010, 05:39 PM
Solved it. I didn't know there was a vacuum line that went to the trans. Hooked it up and everything's smooth as silk now.
Old 04-02-2010, 06:28 PM
Crosley's Avatar
Wiki Edits: 1659
There is no vacuum line on a 700r4 trans. Only the TV cable
700R4 Late shifts yesgo Transmission - Rearend 12 05-06-2007 03:27 PM
SRTA (700R4) shifts late % Too hard PLWC Transmission - Rearend 1 02-15-2007 05:20 PM
late shifting TH350 red_rider52 Transmission - Rearend 18 12-19-2005 09:32 PM
th 700 shifting hard 68bird Transmission - Rearend 5 06-28-2004 12:35 PM
wiring in a late model 700r tranny TooMany2count Transmission - Rearend 5 09-28-2003 07:00 AM
