Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r slipping rev and no 3-4 check ball question
Old 01-14-2013, 11:47 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
Based on the info you are giving,a missing or mis-placed check ball can cause all kinds of problems in any transmission,especially in a modified valve body application like you have,where a lot of the oil flow patterns are changed..If everything air checks good,on the bench,and thru the case with the valve body off, then I would put the checkballs where they belong,make sure the valve body gaskets are installed on the seperater plate correctly, not mis matched,and put it back in the car.
