700R slips into second - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2006, 07:54 PM
I've had some tranny problems with 700s but I think ,or thought that is, that I had them covered. The 700 I have now pops into gear quickly and shifts into drive and overdrive nicely but from low to second, it takes a while. It will shift but it drags it out. Any ideas?
Old 08-08-2006, 05:55 AM
what year
what year is your trans if it has a kick down cable you can adjust them I dont know much about the vac systems
Old 08-08-2006, 09:02 PM
The trans is out of a 1984 Camaro. I have adjusted the T.V. cable as per Bowtie Overdrives specifications and have played with it myself. All is fine except the shift into second.
turbo 400 or 700R trans? Trick101k Transmission - Rearend 3 11-19-2004 12:58 PM
how does 700r know when to shift? manoso Transmission - Rearend 4 05-22-2004 11:20 AM
700r shift? manoso Hotrodders' Lounge 2 05-16-2004 05:52 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
Best place to buy a rebuilt 700r tranny??? bg Transmission - Rearend 3 03-15-2003 01:51 PM
