700r Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2008, 03:25 PM
700r Transmission
I have a 82 chevy with the 700r tranny. It was shifting fine up until about a month ago. I replaced the governor which wasn't working right but in front of the governor I discovered the case wiring has no power to it, key on or off. I follwed the hot lead to the back of the fuse panel. Question is can I reroute that hot lead from something else without having to pull the fuse box out? Also is it supposed to have power with key on or off?
thank you,
Todd
Old 05-08-2008, 12:02 AM
SSedan64's Avatar
It only has power when the vacuum is low enough to lock the Torque Converter Clutch in 4th gear.
Old 05-08-2008, 07:24 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
IF your vehicle still has the vacuum switch inline with the 12 volt power source to the 700r4 trans... it will provide power(12 volts) to the trans with high vacuum.
This setup would unlock the converter clutch IF the vacuum dropped low enough ( as you apply throttle) .
Old 05-08-2008, 02:58 PM
SSedan64's Avatar
Crosley's right. I had it backwards as usual. LOL!
700R in a 1969 Chevy Howie1 Transmission - Rearend 8 01-13-2007 05:07 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 01:03 PM
700r transmission problem mjhendrix Transmission - Rearend 3 09-14-2003 08:46 PM
