700r to turbo 350 speedo - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2009, 05:24 PM
we are about to install a 350 turbo in my sons 88,truck, my question is about the electronic speed odometer. can the 700 tail shaft and gear on the out put shaft be installed on the turbo 350. it is a 6 inch tail shaft.
Old 12-21-2009, 07:03 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
for the electronic speed-O , the reluctor wheel (metal ring thingy) will fit the t-350 shaft.
You will need a buick - olds - pontiac tail housing of 6 inch length for the t-350 trans to install the sensor into.
the 4l60 - 700 tail housing is too long
Old 01-14-2010, 12:50 PM
what year tailhousings, just wondering because I want to do the same to my 89, it has a 400 now and personally I have never had any luck with them and this one is going south now so a good ol reliable 350 needs to be put in place.
SBC Motor and a Turbo 350..Will it work? 31fordcoupe Engine 2 10-06-2009 10:40 AM
350 Turbo Locking up in L1 chrispc88 Transmission - Rearend 4 07-23-2009 12:33 PM
need help deciding on using 700R or turbo 350 TheCiscoKid Transmission - Rearend 7 09-06-2006 11:54 PM
SBC 350 and Turbo 350 OR 2 spd Powerglide??? boneyard Buick Engine 5 04-04-2006 12:34 PM
350 turbo or 400 turbo? nd500 Transmission - Rearend 2 02-21-2003 08:25 PM
