700r vavle body - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2012, 08:13 PM
700r vavle body
need eletrical pic and wireing of switch
Old 02-22-2012, 10:13 PM
Wiki Edits: 85
You must provide more information to get the correct diagram. There are 4 different locations for switches on 700 valve bodies and those valve bodies can have 1, 2, 3, or all 4 switches in any of those locations. Also, there are about a dozen or so different wire looms for the 700 depending on which switches are located where.
Old 02-23-2012, 09:20 PM
SSedan64's Avatar
Some Info here http://www.rowand.net/Shop/Tech/LockupTCCWiring.htm but, as Merlin said there're many different styles.
89 700r valve body question for lockup bckwdz78 Transmission - Rearend 22 09-20-2011 05:50 PM
vavle tap i need help!!!!!! chevyman2993 Engine 2 05-17-2010 10:29 AM
m/t vavle covers smrat Engine 3 06-06-2008 02:55 PM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
manual vavle body...? 73monte Transmission - Rearend 5 12-14-2003 07:57 PM
