700R wiring / to connect or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2004, 07:30 AM
I just installed my 700R in my 1962 chevy pick up ,after installing a shift kit from tansgo. It runs and shifts great. Tv cable installed. I did not install any wiring yet, should I and if so why?.......
Old 05-22-2004, 03:44 PM
Crosley's Avatar
Wiki Edits: 1659
Cool
you need the converter to lock up in at least OD to avoid over heating the tranny.
If you run in OD and the engine RPM is at or in the stall RPM range of the converter the tranny will heat up
Old 05-22-2004, 07:41 PM
302 Z28's Avatar
Bowtie Overdrives has a lockup kit that includes a pressure switch, solenoid and wiring harness for $70. Everybody else gets $125+ for the same thing.
Vince
Old 05-23-2004, 09:58 AM
dmc12mk3's Avatar
Last journal entry: Fixed some leaks
TCI does one for a good bit less than $125 too. I've used this one but wasn't able to get the vaccum switch to operate like I wanted. Turned out I didn't even need to worry about it and just wired it up to lock in O/D or when I flipped a switch under my dash.
http://www.jegs.com/cgi-bin/ncommerc...06&prmenbr=361
Old 05-23-2004, 11:32 AM
airworld2's Avatar
700 wire for lockup
what year is the tranny ???? you can install the wire your self and wont cost more than 35 bucks at the most>>> ask me how
Old 05-23-2004, 07:08 PM
According to the ID it is a 1986 with the square connector facing up. How can I wire it up for $35.00 thanks..............
Old 05-24-2004, 01:36 AM
per per is offline
Hi
How can i ID the trans (TH700) Is there a number?
Where can i look?
Per
