700r Wont Shift Out Of First - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2010, 10:53 PM
I HAVE A 1970 C20 WITH A 454 AND A 700R TRANSMISSION WITH A 14 BOLT REAR END I BOUGHT THE TRUCK AS SAID. I WAS WASHING UP THE MOTOR WITH ENGINE BRITE AND POSSIBLY GOT THE TPS SENSOR AS SHOWN ON THE LINK WET.THEN I TOOK IT FOR A DRIVE DOWN THE STREET PRETTY MUCH GUNNED IT ALL THE WAY UP FROM 1RST TO 2CND AND SO ON... THEN JUST DROVE IT ON D AND SHIFTED FINE THEN ALL OF THE SUDDEN IT WOULDNT SHIFT OUT OF FIRST GEAR...THIS HAPPENED ALL OF THE SUDDEN NEVER HAD ANY PROBLEMS TILL AFTER THE ENGINE WAS WASHED...I CAN SHIFT MANUALLY FOR FIRST TO SECOND ...WOULD THIS BE A RESULT OF THIS MODULE/SENSOR BEING WET OR DAMAGED...HOW CAN I TEST IT?
http://www.compperformancegroupstore...Category_Code=
Old 10-12-2010, 08:53 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Welcome to Hotrodders.com Glad to have you with us.
Check the governor gear it may be broken or apple cored,
common problem with this trans.
Good luck,
Rich
PS You might try typing in lower case
Old 10-12-2010, 11:31 AM
Can you post a diagram of were the governor gear is located? Am not familiar with these trannys or motors ...so you think the TPS SENSOR/MODULE has nothing to do with it ?
Old 10-12-2010, 11:54 AM
tnsmith10's Avatar
when will it rain???
are you sure its a 700r4 and not a 4L60E? also, i saw that you mentioned that after you noticed the problem that you caould get a manual 1-2 shift which does not coincide with a broken governor gear. sounds like maybe some trash could have gotten in the tv valve and is keeping the trans pressures high, and the trans is seeing high line pressure which will keep the trans from shifting normally.
*EDIT* i just saw the link you have up and what you have there is for a 4l60e. not a 700r4.
Old 10-12-2010, 12:25 PM
Old 10-12-2010, 12:32 PM
Well am not even shure what tranny it is that part on the link is what my truck has next to the carburator exactly the same one ....my dad is the one who cleaned up the motor he said that part got wet and he sprayed acid around it also ... but I do have a manual 1,2 gear ..... third or drive kinda rides the gear but slips ....
This is what my tranny says on the side,
Hydramatic
8684198-2
Old 10-12-2010, 02:48 PM
Hi,
Location of governor
http://www.dragracingonline.com/tech.../0409/gov2.jpg
The location of the governor on a TH-350 is behind this cover. For TH-400 and 700R4 the location is the same.
Picture of governor
http://www.dragracingonline.com/tech.../0409/gov3.jpg
Old 10-12-2010, 03:08 PM
Pictures of transmission pan shapes.
http://700r4.com/trans/comparrison.html
Picture A- 700R4 Picture B- 4L60 Witch one do you have?
http://image.hotrod.com/f/9000875/11...ector_hole.jpg
Old 10-12-2010, 03:15 PM
Looks like a 4L80
Old 10-12-2010, 06:45 PM
How to check the TPS
http://www.wonderhowto.com/how-to-te...sensor-267168/
Old 10-12-2010, 08:56 PM
Last journal entry: hillbilly ratrod
trans prob
hello,maybe i can help.... 4l60-e trans,wet?...check 4 tps grounding out.also check for blown fuse..labled..trans on fuse block, this is a ecm controled trans .thank-you
4L60e 2-3 shift slow after installing kit ckucia Transmission - Rearend 3 09-01-2009 12:09 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
how does 700r know when to shift? manoso Transmission - Rearend 4 05-22-2004 12:20 PM
shift manual vs automatic 700R manoso Transmission - Rearend 1 05-19-2004 02:20 PM
700r shift? manoso Hotrodders' Lounge 2 05-16-2004 06:52 PM
