700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2003, 04:23 AM
New Member
Post 700R4
My 700R4 shifts into 4th gear overdrive to soon, about 30 MPH. Same thing about down shifting out of overdrive. I would like to change the shift point into and out of overdrive to about 45 MPH. Can this adjustment be made by adjusting the Throttle Vacuum cable? <img src="confused.gif" border="0">
[ February 03, 2003: Message edited by: Larry Day ]</p>
Old 02-03-2003, 06:00 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Yes it is likely the TV cable but this isn't to be adjusted by eye like you can on a TH350. Very critical adjustment on an overdrive tranny so I suggest you have it done at your local tranny shop or contact these guys if you want to try it yourself.
<a href="http://www.bowtieoverdrives.com" target="_blank">www.bowtieoverdrives.com</a>
Old 02-04-2003, 11:08 AM
Post
[quote]Originally posted by Larry Day:
<strong>My 700R4 shifts into 4th gear overdrive to soon, about 30 MPH. Same thing about down shifting out of overdrive. I would like to change the shift point into and out of overdrive to about 45 MPH. Can this adjustment be made by adjusting the Throttle Vacuum cable?
[ February 03, 2003: Message edited by: Larry Day ]</strong><hr></blockquote>
There is one adjustment for the TV cable, it's not to be used to change shift points. So make sure it's adjusted right.
You can raise the 3-4 shift point and lower the 4-3 downshift point usually by swapping one governor spring for a weaker one. A 10 minute job on most vehicles.
