700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2003, 10:50 AM
Post 700R4
Hi All
I have a 700R4 that won't shift from 1st to 2nd until the throttle is opened fairly wide and then released slowly, after that it shifts O.K. I have checked the TV Cable setting and it seems O.K. Please help!!!!
Regards,
Kevin.
Old 04-10-2003, 11:48 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
How did you 'check the TV cable'? That adjustment is critical and not obvious by inspection. Is this a factory installation or a swap? If the latter, your cable is likely misadjusted.
