700r4 or is it - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2007, 10:18 AM
Im trying to have an idea!
700r4 or is it
Last post
Well Im in the process of installing this trans in my truck. I came across this little bugger (see attached pic), I had no clue what it does. Went thru my caprice manual, it does not show. Then I noticed that the pics in my manual are a bit different from what my trans looks.
Am I mistaken this trans for a 700r4? the closest trans that it looks like is a 250c! What is a 250c? I have never heard of this kinda trans, but my book has one called out in 84 (the trans i have is from an 85 caprice with OD).
What is that little electrical connection for???
Old 07-13-2007, 11:06 AM
Jmark's Avatar
Don't take this as fact, but to me it looks like a TH350C trans. It has a modulator so it's not a 700R4. The angled corner on the pan the the 2-3 accumulator cover and pressure tap look just like the TH350. Add the plug to all of that and my GUESS is the lock-up version of the TH350.
Mark
Old 07-13-2007, 11:18 AM
700r4
This is a THM350. The switch you can see is not for lockup, but as far as I can remember was tied into a/c or vacuum advance[for timing].
This switch was famous for leaking, so if you use this trans remove the switch and install an 1/8 inch pipe tap plug.
Old 07-13-2007, 12:05 PM
Mark
I pulled this trans and motor from a 4sp caprice...I still have the 1985 caprice.
Old 07-13-2007, 12:15 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I think the 350c would have the computer plug on the linkage side?
I talked with a friend recently who used to build custom use automatics. I asked him if a 350c could be set up to lock & unlock without a hand switch or computer. First, he said why?, then, why not a 700r4? So I explained I already went to a 2.76 rear and on the highway I just need a little extra drop in rpm. (plus I never liked the wicked low 1st gear in the 700)
He said it could be done, but I don't recall what he said about the mods. Sounded easy though.
I didn't want a manual switch.
IMO, the 350c would work slick in certain vehicles with the right gear & motor.
Old 07-13-2007, 01:38 PM
Jmark's Avatar
And the words from the experts are always welcome! LOL Glad I qualified my reply with "Guess" and "don't take this as fact"!
But I was atleast close!
Mark
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 01:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
