700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2007, 09:07 AM
700r4
I am having , I think, pressure problems in the trans. Is there a pressure release valve on a 700r4 trans, and if so, where is it located. When I fill the trans to fill level on the dipstick, I don't have a leak problem. When I drive the car and put it away in the garage, it looks like you poured a quart on the floor. The leak is coming from the detint cable. I have removed the cable, cleaned all fluid off, put a small amount of atv and a new rubber seal, re-installed after a set up time for the atv and still have fluid coming out of the cable mounting area after driving. I am quite complexed right now....Suggestions?
Old 08-19-2007, 09:21 AM
There is a vent pipe on the top of the trans towards the center.
Old 08-24-2007, 09:00 PM
Gr8 '48 bow tie's Avatar
Be American, Buy American!
Did you mean perplexed instead of complexed?
Perplexed - Confused, do not understand the problem.
Complexed to my knowledge is not a past tense for complex.
It sounds as though you are complicated instead of the problem being complicated ( a past tense of complex).
This is not ridicule or a put down in any way. Just a little information in case you did not know the difference.
Al
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 01:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 02:04 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 06:44 PM
