Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4
Thread: 700r4
Old 05-04-2012, 08:10 AM
4theluvofchevys 4theluvofchevys is offline
seems to shift fine and there is no slack in the t.v. cable at wot.when i did take the pan off there is a singal wire that goes to the solenoid so thats a self grounding one. There is only two wires that came in the plug with this tranny one (blue) was for the brake switch it was orange for the t400 as for the green one I did put 12v power to it and now it seems like its locking in third goes to forth not a bad shift and its doing 2300 rpm at 60mph with 4:10 rear, Before when there was no power it was like 2700 rpm. The wires do run through a vaccum switch, this switch should only allow power through when there is enough vaccum, correct so if its letting power through all the time then that switch is nfg, does the 700 only need power to lock up? Maybe i'll put the power on a toggle switch let it get to forth then flick the switch and see if it locks.
