Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 700r4
Thread: 700r4
Old 01-07-2013, 03:54 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: 33 WILLYS
You can take a large fine flat file and lightly go across the entire trans case where the valve body bolts on,and knock any high spots down.Don't focus on 1 area,go across the whole thing evenly....brake clean and blow dry when done...and the groove in the case webbing:as long as it doesn't go from 1 channel all the way thru to the 1 next to it,then it will be ok. If the seperator plate got beat up from the checkball,then it will have to be replaced.
