700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-28-2009, 03:56 PM
700r4
i just finished rebuilding a 700r4 in a 1985 camaro, when i did road test i have no 2nd gear or 4th gear i checked servo seems like it's not clamping band hard enough,took servo out replaced with one out of corvett with shorter pin still same results. also did main line pressure test and was over specs.I also did air check on the servo port and can see the band react but doesn't seem like enough pressure to hold drum.when the band is new and hasn't been flexed.when i checked third gear pressure i came up with 60 psi gradually, i've checked ports and nothing seems clogged? any idease?
700R4 into 79 Chevy Truck Torque454 Transmission - Rearend 7 03-08-2009 11:33 PM
A few Questions on a 700R4 swap. zbhover Transmission - Rearend 2 02-24-2009 06:13 PM
700r4 conversion questions eric63chevy2 Transmission - Rearend 7 07-03-2007 02:37 PM
Putting a 1987 700R4 in my 1982 GMC 4x4... indy_85stariones Transmission - Rearend 12 04-28-2007 03:04 PM
Need advice: 700R4 banging in 1st 360Camaro Transmission - Rearend 11 11-20-2003 07:44 PM
